Author Topic: Capacitor Surface Mount question  (Read 316 times)
Offline CramboneTopic starter
« on: December 31, 2024, 08:12:17 pm »
I’m looking for a 20n 1kv surface mount capacitor, it measures 3.2mm long, 1.5mm wide & Depth dosent mattter
Andrew
Offline Solder_Junkie
Re: Capacitor Surface Mount question
« Reply #1 on: December 31, 2024, 11:05:18 pm »
You didn’t look very far. Took a few seconds on Mouser.com Part number 581-1812AC203KAT1A
SJ
Offline thm_w
  • Non-expert
« Reply #2 on: December 31, 2024, 11:11:18 pm »
The 1812 above is:
Length:    4.5 mm (0.177 in)
Width:    3.2 mm (0.126 in)
Height:    2.54 mm (0.1 in)
So yours might be 1206
Possibly either would fit.
« Reply #3 on: December 31, 2024, 11:17:06 pm »
Oops, 1206 size at Mouser 80-C1206C223KDRAUTO
SJ
Online wraper
  • Country: lv
« Reply #4 on: December 31, 2024, 11:33:29 pm »
Andrew
It's easy to find a suitable part in 1206 or 1210 package in any catalog using parametric search. https://eu.mouser.com/c/passive-components/capacitors/ceramic-capacitors/mlccs-multilayer-ceramic-capacitors/multilayer-ceramic-capacitors-mlcc-smd-smt/?capacitance=0.022%20uF&case%20code%20-%20in=1206&voltage%20rating%20dc=1%20kVDC
« Reply #5 on: January 01, 2025, 12:01:11 am »
Thanks guys the surface mount is new to me
Drew
