There is no issue using IC with lower access time. Access time is rated for worst case only, therefore it's easily possible that some 90ns IC actually can be faster than 70ns IC.
do you why they made different acces speed ic with so little difference if it's not that important ?
It is important if you need to operate them fast. It's not like they have a different silicon die. Manufacturer bins them in production and can sell faster ICs for more. If they produce more of faster ICs than market demands, manufacturers often sell faster ICs as lower grade.
