On what?
FYI, "RMS power" is meaningless; there's no reason to take RMS of power, only the peak or average (or whatever other statistics might be relevant, but you'd need a weird circumstance to use RMS with it). The term often comes up in audio, I think typically meaning either the peak or average power at rated output for a sine or square wave signal, based on its measured voltage RMS or something like that. Used more to distinguish from peak power, or other even less honest measures (like "PMPO", which is, as far as I know, wholly devoid of meaning).
