Author Topic: L293D & Arduino - Where I connect the 12 volt ground  (Read 1462 times)
Offline Brown
« on: December 21, 2013, 05:25:48 pm »
Hi quick question, I was playing with the L293D Moter driver and Arduino and was wondering do I connect pin 8 of the L293D to a +12v and the ground to the ground of the Arduino. This is what I was doing http://learn.adafruit.com/adafruit-arduino-lesson-15-dc-motor-reversing/overview Thanks!
Offline mortos360
  • Country: at
Re: L293D & Arduino - Where I connect the 12 volt ground
« Reply #1 on: December 21, 2013, 06:08:31 pm »
that tutorial uses 5V... where did you get 12V?
Offline Brown
« Reply #2 on: December 21, 2013, 06:12:25 pm »
I know but I have a bigger motor that won't run on 5 volts
Offline DrLuke
    • Opensat.Space
« Reply #3 on: December 21, 2013, 06:38:17 pm »
Where are you getting the 12V from? Are you powering the Arduino from the same 12V?
Offline Nerull
« Reply #4 on: December 21, 2013, 06:50:04 pm »
You would connect pin 8 to +12V, pin 16 to +5V from the arduino. Connect the ground to your 12V supply and connect the ground from your supply to the arduino ground.
Offline Brown
« Reply #5 on: December 21, 2013, 07:19:12 pm »
DrLuke, no I'm using a separate 9 volt but thanks Nerull it worked!
