I wonder if anyone have an experience with the Stall detection of the L6470. I can't find a way to make it detect properly when I stall the shaft by hand.
Adjusting the stall threshold is tricky, the flag is either tripping while running with no load (Set too low) or not tripping at all (Set too high). There is no sweet spot.
Does this feature only work when you are dealing with high current (lets say < 2A), so the change of current is actually meaningful. Or am i missing something...
Thanks.
