I'm trying to understand how the remote control on my TASCAM DR-40 PCM recorder works... I'm trying to make a remote start that is triggered by a uC rather than the wired connection provided by the RC-10 accessory. I bought the RC-10 to see how it works, and so far it's a bit of a mystery.
The RC-10 itself is an infrared transmitter, but the DR-40 only has a wired connection, so the transmitter unit slips into a plastic caddy that provides the wired connection out. I've opened up this caddy and as expected there's an infrared receiver with a bunch of passives, a couple of transistors, and one IC package. All of the components are SMD so the markings are proving tough to track down... The IC is marked "MFN0 1118 8GG" (Images attached)
So, the wired connection contains 3 conductors on a TRS mini jack (2.5mm). Measuring the DR-40 unit (recorder itself) I found that sleeve is GND, but the other two conductors are both 3V3. I was expecting one of them to be a data line...
So maybe the circuit in the remote caddy is doing more than just demodulating the IR signal?!
Does anyone have any tips as to where to start with this? Know what this "MFN0" IC is doing? I don't have a much test equipment - just a multimeter... though I did rig up an Arduino Uno as a basic DSO/logic analyzer
