Author Topic: flip-flop circuit  (Read 1788 times)
Offline yalectTopic starter
flip-flop circuit
« on: February 12, 2020, 10:44:55 am »
I would like to ask you if I can build flip-flop led ciruit using op-amp Lm358 and what it's Working conditions?
Thank you
« Last Edit: February 12, 2020, 11:01:36 am by yalect »
Offline GerryR
Re: flip-flop circuit
« Reply #1 on: February 12, 2020, 11:52:18 am »
I am reasonably sure that if you google "op-amp flip-flop," you will only find about a million, + or -, versions of op-amp flip-flops!  As an example:  https://www.radiolocman.com/shem/schematics.html?di=463517.  Adapting the 358 should be pretty straight forward.  :)
Still learning; good judgment comes from experience, which comes from bad judgment!!
« Reply #2 on: February 12, 2020, 03:01:10 pm »
thank you for your reply
but Features of LM358 allow to make flip-flop circuit?
Offline David Hess
  • DavidH
« Reply #3 on: February 13, 2020, 02:25:12 am »
Yes, an LM358 will work fine in a flip-flop circuit.
Online Zero999
  • 0999
« Reply #4 on: February 13, 2020, 04:12:09 pm »
Coincidentally, I've just been working on a schematic which requires an op-amp bistable. I chose the comparator, rather than an IC or discrete bistable, because the trigger voltage can be set fairly accurately.
Here's the circuit, but using the LM358 and changed so I can post it here. The original design uses an LM393 comparator and is part of a bigger design. If Schottky diodes are used, the forward voltage can be ignored for most applications and the bistable will fire when the inputs are above V2. Using high values for R1 and R2, reduces the errors from the diode forward voltage, but increases the errors from the diode leakage and op-amp bias currents. Adding resistors with the same values as R1 and R2 in series with the non-inverting inputs will minimise the latter.
R3 and C1 form a power on reset circuit, which ensures it always starts up in the same state when power is first applied.
« Reply #5 on: February 14, 2020, 11:32:29 am »
thank you
- I think your circuit based on two part of LM358 not one, why not like following, may it will works?
« Last Edit: February 14, 2020, 11:35:03 am by yalect »
Online Zero999
  • 0999
« Reply #6 on: February 14, 2020, 02:55:07 pm »
thank you
That's an astable, i.e. oscillator, rather than a bistable.
Yes, a monostable can be made with just one op-amp, but there are advantages with using two (see my previous post) and if the other op-amp in the LM358 is spare, you might as well use it for something.
« Reply #7 on: February 14, 2020, 09:31:10 pm »
 - I would like to ask you what the aim of using pulses
in my post for single LM358 part it generates pulses itself,
- as such circuits, there are conditions for the three resistors and C?
thank you
« Last Edit: February 15, 2020, 11:00:39 am by yalect »
Online Zero999
  • 0999
« Reply #8 on: February 16, 2020, 08:50:45 am »
thank you
Your original post is ambiguous. You didn't say what sort of flip-flop circuit you're looking for, so people just assumed bistable, since it's the default meaning of the word flip-flop. There are also monostable (timer) and astable (oscillator) circuits and it now appears you require the latter.
The resistor values in my circuit are not critical. If you read the post again, you'll find I hinted on the advantages/disadvantages of using higher/lower values. Please ask specific questions.
Online Ed.Kloonk
  • Cat video aficionado
« Reply #9 on: February 16, 2020, 09:50:21 am »
thank you
I thought he might have been talking about going for a jog around a beach suburb wearing thongs. (footwear)
iratus parum formica
Offline GerryR
« Reply #10 on: February 16, 2020, 12:55:45 pm »
The OP should have enough info from the above posts to figure out the rest of what he needs by himself.  I was told once not to do a poster's homework for him; heck the whole project was done for him a couple of times.  Just saying.  ;)
