Author Topic: laptop power adapter replacements  (Read 2668 times)
Offline LaserTazerPhaserTopic starter
« on: May 16, 2019, 12:21:07 am »
Can a meanwell or some other quality adapter replace an OEM laptop adapter if the output voltage and current meet or the current exceeds the OEM adapter?
Offline Richard Crowley
  • KJ7YLK
Re: laptop power adapter replacements
« Reply #1 on: May 16, 2019, 12:34:18 am »
Does your mystery load (your unidentified laptop) use a simple 2-pole connector (implying that it operates at a fixed power: voltage/current)?  Or is it something with a more sophisticated arrangement where it negotiates voltage/current with the supply?
If it is a simple 2-pole connector, then it seems likely that any supply of proper voltage and sufficient current will work OK.
Of course it is absolutely mandatory that you get the polarity correct. Else, you will likely toast your laptop as most don't have polarity protection.
Clearly, a fixed-voltage source isn't going to work properly with a load that expects to negotiate the voltage/current.   This is difficult to answer properly as a generic question.
The following users thanked this post: LaserTazerPhaser
Offline CJay
« Reply #2 on: May 16, 2019, 09:48:11 am »
As Richard says, some laptops use electronic 'serial numbers' to verify genuine or not so your lapotop may decide it's not a genuine AC adapter and refuse to charge.
I think you could probably get away with using a Meanwell supply, they seem to be generally OK but beware of cheaper supplies, I've seen significant problems with some cheap adapters which cause very odd symptoms on the laptops they're powering (USB ports not working, noise on audio, random lockups) which disappeared when a genuine adapter was used.
Offline GigaJoe
« Reply #3 on: May 17, 2019, 03:28:30 am »
electronic 'serial numbers' ?
or just resistor on third pin
  • KJ7YLK
« Reply #4 on: May 17, 2019, 04:09:13 am »
USB-C power has four different power (voltage/current) settings.  As negotiated between the load and the supply.
Three of them are standardized at 5V, 12V and 20V (at various currents) plus an additional mode for specialized gear.
Ref: https://en.wikipedia.org/wiki/USB_hardware#USB_Power_Delivery_(USB_PD)
And, as @GigaJoe mentioned Apple started the standard of fixing the two data pins at various voltages to indicate the voltage/current capability of the supply.
Online oPossum
« Reply #5 on: May 17, 2019, 05:33:41 am »
Apple, Dell and HP use Dallas/Maxim one wire devices for adapter capability info and in some cases (mostly Apple) to drive status LEDs.
Offline CJay
« Reply #6 on: May 17, 2019, 08:03:39 am »
Never seen one. Some use a third pin or OneWire to communicate, but none of them actually cryptographically authenticate (unlike iPhones).
I've been using many high end computers, mostly ThinkPads and Macbooks, none of them require the "original" adapter that doesn't have a Chinese clone.
Buy a good power supply, and buy a Chinese cable, marry them together, and you are good.
I didn't claim they did 'authenticate'.
Dell machines used to include a Dallas one wire device, I think it was in the D600 series laptop PSUs that I first saw one (when Win XP was new), memory tells me it was an electronic serial number or ID tag but I really can't remember the part number any more, however, if the part was damaged or disconnected somehow the laptop would power up but refuse to charge.
I *think* I may have a faulty Dell one here which I could disassemble and take pictures of
HP adapters use something similar.
Lenovo use a simple resistor to identify adapter capability.
Apple are a protectionist world of their own.
Again, I'm a fan of the low prices the Chinese manufacturers are able to bring to the market, I'm not in any way knocking clone PSUs, most are perfectly adequate and work as well as the original, just passing on a warning from my experience that some of them are really poor and can cause 'odd' problems.
Offline CJay
« Reply #7 on: May 17, 2019, 09:22:05 am »
Well, I am.
I don't mess with mains, even for 120V systems. Regardless of input voltage, the guts run on ~400V for a PFC PSU.
I'm okay with a cloned cable, but not the adapter itself, unless it's certified like those Belkin/Moshi/etc. MFi adapters.
Then I bow to your superior experience, I've seen some of the things you've posted here and admire your skills.
Maybe I should have said counterfeit instead of clone because I'm in agreement with you, the 'name brand' certified adapters are OK, it's the ones made up and labelled as original or to look so close to the OEM as to be indistinguishable at first glance that are generally crap.
  • KJ7YLK
« Reply #8 on: May 17, 2019, 09:31:31 am »
My laptop computer at the office uses USB-C for power.  It requests the 20V mode from the power supply.  It also uses USB-C to the docking station where I have four displays connected along with keyboard, mouse, etc.  And a USB headset and Skype for Business (since they took away all the phones).
Offline CJay
« Reply #9 on: May 17, 2019, 12:03:02 pm »
We're starting to see machines that use USB-C here too, I believe most of the HP ones we provide now can use it but come with a 'standard' PSU socket and adapter, the HP tablet PCs definitely use it and don't have a 'standard' power socket.
Offline wasyoungonce
« Reply #10 on: May 17, 2019, 12:26:07 pm »
If you adaptor died they are easy to repair, mostly it’s the DC power lead.  They can be difficult to take apart. I use hot knife and re-melt them back together.
Most Chinese knock off adaptors are very poor quality if not downright dangerous.  I tried a few and after looking inside them....never again.
Sent using iPhone
I'd forget my Head if it wasn't screwed on!
« Reply #11 on: May 18, 2019, 07:40:22 am »
Sent using iPhone
Aren't many bricks potted for greater thermal transfer?
Seems only Mac bares those elongated multi connecting charging plugs for laptops. I was referring for ordinary 2 pole connectors.
USB type C should really be replacing these things especially with the availability for magnetic type c adapters. With the great burden of backwards comparability with USB Type A which Type C must operate with - counterfeits are very much in position to do great damage to consumer goods with their faulty, unreliable or inoperable components with which their likely to be constructed with.
« Last Edit: May 18, 2019, 07:44:01 am by LaserTazerPhaser »
« Reply #12 on: May 18, 2019, 07:56:05 am »
[/quote]
[/quote]
Some are most not.  Most use a white silicon type potting on bigger components for mechanical stress.  It’s easy to pick off.  Most bad adaptors have bad connectors it’s usually easy to access the pcb to replace this as it’ll be soldered right at one end edge.
Sent using iPhone
Online radiolistener
  • Country: ua
« Reply #13 on: May 18, 2019, 10:48:26 am »
Most of Chinese cable are very bad for power supply. They has too high resistance which leads to high voltage drop and power loss. Also they bad soldering and requires to use acid in order solder it.
I recommend to buy some good cable from real copper instead of Chinese silumin cables named as "copper".
« Last Edit: May 18, 2019, 10:51:26 am by radiolistener »
« Reply #14 on: May 19, 2019, 07:03:07 am »
Meanwell bricks aren't potted?
« Reply #15 on: May 19, 2019, 10:27:31 pm »
Define potting.
They have silastic gunks, but are not fully potted.
It is a highly price sensitive market, and no one is putting dollars worth of gunk in a consumer device anymore.
FFS, even BGA chips nowadays are not underfilled.
OTOH, power MODULES are usually potted due to higher profit margin, and higher density requirement (you get to circumvent UL/IEC creepage and clearance requirements by "cementing" exposed coppers with dielectrics). Also, vibration, drop test and thermal shock tests sometimes are only passable with potting.
Some super high density consumer power bricks are potted, like Innergie (Delta)'s so called GaN (which is not) 60W USB-C adapter that is not much bigger than an iPhone cube charger. But when you sell a power brick at $100, you can afford it.
Most MeanWell bricks have a semi-enclosed internal structure. Inside the plastic case, there is usually a metal shield, which is also heatsink of the guts. The metal shield is gunked to the guts with silastic rubber, and sometimes the entire structure is also strategically and selectively taped with Mylar to enhance insulation. But no, it's not fully encapsulated.
Meant potting as components are no longer accessible since entirety of open space is filled with epoxy.
« Reply #16 on: May 20, 2019, 03:16:48 am »
Then no.
BTW, epoxy potting over large area is a bad idea, unless it's formulated to match CTE of the chips. It's more for obscuring the module to deter reverse engineering than to provide protection.
For protection, hard rubber is better. You will see modules from proper brands (Vicor, etc.) use hard silicone rubber for large modules, and CTE matched epoxy or other molding material for small LGA modules.
Are there any blogs or similar sites showcasing meanwell or another reputable power supply such as TDK lambda brick board and components?
  • KJ7YLK
« Reply #17 on: May 20, 2019, 05:01:27 am »
If you want top-of-the-line power supplies (and are willing to pay the top-of-the-line prices) you can look at https://www.acopian.com
Offline TimNJ
« Reply #18 on: May 21, 2019, 12:58:29 am »
http://www.chongdiantou.com/
Chinese only. Need translation.
This is one of my favorite sites! The tend to showcase mostly Chinese brands, which may OEM for some "American" brands.
I have no problem with Meanwell. They sell *a lot* of power supplies, which means they can actually make a decent quality product at a reasonable cost.
It's when you buy the eBay no-name, no-regulatory-marking adapters that you run into trouble.
Offline Liam
« Reply #19 on: May 21, 2019, 05:36:21 am »
The most logical in this situation to contact the manufacturer or their technical support. Remember the cost of a mistake can cost the life of your computer.
« Reply #20 on: May 21, 2019, 08:00:32 am »
There aren't any posts showcasing meanwell wall mounted or desktop adapters.
