get a 499 ohm and 1 ohm, or simply 499 will do, why you need so accurate? circuit that needs that accurate value, if not exceeding few GHz BW is flawed imho. few minutes ago i concluded on my order in lcsc, some of them are various values of smd resistors. i skipped the 0.01 ohm 0603 type because it was unusually 10X more expensive than the rest, although the bigger 0.01 ohm 0805 is finely priced, go figure. unluckily 500 ohm value also not available in lcsc, out of stock or not currently made not sure. otoh, i was having difficulty getting 50 ohm resistor, so i just get the 49.9 ohm, next candidate is 50.1 ohm, should be not far off...
