It's a solar transfer switch (Latronics SATS), I basically have to connect two terminals (2 & 6) together, this switches my solar panels to a different output, it will probably be done once a day and terminals 2 & 6 will be connected continuously for many hours at a time.
I'm thinking I want to use a latching relay, I want to drive it from an MCU I already own (Olimex ESP32-POE), reading some of the 5v latching relay specs you need at least 1A to switch them, my MCU has just over half that at 600mA @ 5V.
So am I barking up the wrong tree with latching, my thinking is terminals 2 & 6 might be connected 50% of the day in summer and so latching makes sense?
If latching makes sense whats the easiest way to get my 1A to switch it, I only need to switch very infrequently, one or two times a day, my MCU also has a LiPo battery charger.
What would you use?
Thanks.
Richard
