Author Topic: Mysterious black insulation stuff?  (Read 481 times)
Offline Ford
« on: October 27, 2020, 03:43:03 am »
I'm an undergrad who came into posession of some large power electronics things. Upon investigation I noticed two of these things are absolutely filled with this hard black rubbery stuff. I think it's insulation, brittle due to age, but I'm not sure. I'd like to remove it so I can get a better look at the parts inside these devices and I'd also like to know if what I'm looking at is actually some sort of old rubber insulation. I've elected not to mess with any of it further in case it's some sort of dangerous material containing asbestos and what not (I've been told these devices are quite old).
Any information on what it is would be helpful, as I can't find anything about it (or pictures) online by searching along the lines of "transformer black electrical insulation" or "power electronics rubber insulation" etc. If anyone has an advice on how to remove it I'd be glad to get that too. I don't care to save or reuse the devices, so destructive methods are acceptable.
Here are pictures of the mystery stuff: https://imgur.com/a/hzTQPSS
Thanks and I'm glad to join the forums.
Online Shock
Re: Mysterious black insulation stuff?
« Reply #1 on: October 27, 2020, 04:30:32 am »
It's called Potting Compound.
Multimeters: Fluke 87V, 117, 27/FM       >>> WANTED STUFF <<<
Offline helius
« Reply #2 on: October 27, 2020, 04:44:57 am »
The common encapsulants (potting compounds) are silicone, epoxy, and urethane. Removing them is a messy process but it is possible.
There was a video linked several years ago here about decapsulating a power transformer, I wonder if I can find the link...
Offline gcewing
« Reply #3 on: October 27, 2020, 05:58:17 am »
Here's a video from Mr. Carlson's Lab where he depots an old power transformer filled with tar:
Whether his method would work for you depends on what kind of potting compound your device has.
Offline helius
« Reply #4 on: October 27, 2020, 06:15:43 am »
Here's a video lesson from PACE showing more typical encapsulants.
There's an emphasis on equipment sold by PACE in that time period (not currently available from them), but the principles are the important part. It is also possible to soften certain resins by just boiling them in water. That is not ideal from a high-reliability electronic standpoint, but it does work, and most circuitry can survive being boiled if given sufficient time to dry out before power is applied.
The following users thanked this post: S. Petrukhin
Offline perieanuo
« Reply #5 on: October 27, 2020, 07:59:13 am »
hi,
there are lot of rosin compounds out there, each of them has specific use cases. each case need to be studied, we tested several solutions for laser manufacturing for example (it had to be moisture proof, sealed for avoiding power modification for the laser diode etc etc).
so for some apps you need specific rosin compound, for others it may be different (for example, if the board is heating a lot you may choose other rosin)
fluidity is also an important parameter in pcb compounds
regards, pierre
Online Shock
« Reply #6 on: October 27, 2020, 11:12:05 pm »
They actually still sell those type of tools, but they aren't really intended for diy or a single use.
https://paceworldwide.com/mc-65-microchine
https://paceworldwide.com/lf-15-thermopart-lapflo-handpiece
https://paceworldwide.com/smr-multi-function-pulse-heat-rework-station
Offline helius
« Reply #7 on: October 28, 2020, 05:43:48 am »
When you find the link to buy Freon TF, let me know, 'k?
I am also interested in any devices like the SU-101 spray unit shown @13:15.
OP: The larger device is a neon sign transformer. When messing with these, you do need to observe the one-hand-in-pocket rule: 15kV at 30mA can really sting. It is potted either in tar or silica-loaded urethane; you may be able to tell by touching the material with a red-hot pin and smelling the smoke. I seem to remember that the potting is required for anti-arcing protection on that type of unit.
