Hello
I am working on a led thing with a constant current LED sink PWM driver.
The LEDs I am using are common anode RGB leds.
The max R voltage is 2V
The max G/B voltage is 3V
The LED power supply is 3V but I need the red led to run at 2V
My LED driver max current is set to 20mA
Can I use a 50 ohm resistor between R and one of the driver outputs to get 2V on the LED instead of 3V?
I got the 50ohm value by using this equation:
R = (Vs - Vled) / Iled50 = (3 - 2) / 0.02
This is what the schematic would look like including the driver output:
I don't have much experience with this LED driver stuff so I wanted to ask this here before I make my pcb for the project.
Thanks.
