Author Topic: Variable delay nanopulser  (Read 912 times)
Offline SrgTopic starter
« on: January 28, 2019, 04:11:58 am »
Can anyone tell me about this unit.  What it was used for and what it can be used for?
Thanks for any help
Offline Zero999
  • 0999
Re: Variable delay nanopulser
« Reply #1 on: January 28, 2019, 09:16:37 am »
It's a pulse generator.
It can be triggered by an external signal or generate a square wave, depending on the settings.
Offline David Hess
  • DavidH
« Reply #2 on: January 29, 2019, 07:35:54 pm »
The high voltage on the "width" connector indicates that it is an avalanche pulse generator and the width is controlled by an external charge line.
The sync output and delay indicate to me that among other things it was intended to be used with sequential sampling oscilloscopes that require a pretrigger signal.
Offline GonzoTheGreat
  • Country: aq
« Reply #3 on: January 30, 2019, 10:30:42 am »
I know this unit. Yes it is used as a pretrigger in older scopes but the generator is based on a DSRD - not on an avalanche breakdown.
