Author Topic: Pads right on edge of board cutout - clearance?  (Read 692 times)
Offline AQUAMANTopic starter
« on: February 25, 2020, 09:20:25 pm »
I need to have pads on my PCB right next to a cutout and also at the edge of the board
Altium is giving me a rule error for this, even though there is no cutout or outline clearance specified
Will this be a problem in manufacturing if i have pads right on the edge of cutout and board outline?
Offline johankj
  • Country: no
Re: Pads right on edge of board cutout - clearance?
« Reply #1 on: March 05, 2020, 02:34:41 pm »
I wouldn't think so, this is basically what is done using Plated Half-Holes/Castellated Holes: http://support.seeedstudio.com/knowledgebase/articles/910767-what-are-plated-half-holes-castellated-holes
Online thm_w
  • Non-expert
« Reply #2 on: March 05, 2020, 10:55:55 pm »
You need to check with the PCB vendor as to their specifications. They may charge extra in the case of castellated holes. Although in this case it looks like the pads should not be cut so might be ok.
JLC states "trade to outline" as being >0.2mm for example.
Clearance to board edge? The plane is pulled back from the edge as well, so maybe a general clearance rule.
