Maybe a bit more about the "why" I'm trying to do this: My Boiler is sitting in the south facing side of the house and the temperature sensor should be mounted in the north. I want to avoid adding a new wire through the whole building, so instead of using the "real" NTC I want to connect the simulated one controlled by temperature data from my own weather station. So in general I don't really need to change the temperature curves of the boiler, I just need to find a way to feed in the outside temperature. If the boiler was supporting Opentherm (or ebus, etc.) that would be easy, but as it is a quite "dumb" older system, I need to go this rather convoluted way...
