Electronics => Beginners => Topic started by: PinheadBE on August 17, 2024, 03:10:50 pm
Title: Lead-acid battery: What does this mean?
Post by: PinheadBE on August 17, 2024, 03:10:50 pm
Dumb question, but what does that "20Hr" parameter mean?
(See pictures)
Title: Re: Lead-acid battery: What does this mean?
Post by: wasedadoc on August 17, 2024, 03:15:27 pm
It means 2.2Ah capacity if you discharge at the rate that takes 20 hours. ie 110mA.
Post by: PA0PBZ on August 17, 2024, 03:18:45 pm
See attachment.
Post by: PinheadBE on August 17, 2024, 04:00:53 pm
Thanks to both of you.    Very clear!    :-+ :-+
Post by: Stray Electron on August 18, 2024, 01:06:32 am
   It means that they discharged the battery at an extremely low rate so that it yielded the maximum number of amp hours for their test. It also means that in real world usage you're probably never going to get anywhere close to the rated number of Amp-hours.
   Look at the data sheet that PA0PBZ linked to and you will see what I mean.
Post by: J-R on August 19, 2024, 06:10:43 am
Side note, the 20 hour rating is a standard in the industry, and the lower capacity at higher rates is an unavoidable aspect of lead acid batteries' chemistry.  A proper lead acid system design will consider this, as well as avoiding a high depth of discharge.
However, lead acid is cheap and common, so they've ended up in perhaps less-ideal applications such as computer UPS devices, where in some cases they only last a few minutes.
Lithium ion chemistries don't have this characteristic of losing capacity at higher discharge rates, so there are applications where they might be advantageous, usually revolving around weight.  For the price, in stationary applications, you can typically just build a larger lead acid bank for the same money and plan for say a 25% depth of discharge, with the minor advantage of now you do have a larger reserve capacity if needed in case of emergency.
When designing my battery backup system, I planned for a full discharge to happen over 24-72 hours, depending on the outage situation.  In case of a major storm which knocks out infrastructure, I go into conservation mode and only run critical loads, for example.  I was able to get approximately 5x the capacity with lead acid as lithium ion for the same price.
Post by: PinheadBE on August 19, 2024, 02:09:14 pm
Thanks for the side note.
In my case, it is a very simple use-case: we suffer more and more power outages, lasting from 1 to max 3 hours.
I have already a commercialy built UPS for my NAS and router
But I lack a system to be able to open my front door which has an electric opening system, commanded by a RF receiver.   All of it is powered by 12 VDC.
Therefore, I'll built a very simple UPS based on a lead acid battery and a charging module based on the CN3768 chip.   Some diodes and voila....
The current drawn by the RF receiver is less than 2 mA in standby, so a simple 2.2 Ah battery should be sufficient.
Thanks to all for your help  :-+
