I have considered a proper "ambilical". I even had a thread on here about it and got good advice.
There are many options for power about 5 meters away in the garage, two solar systems, a 24V.1kW rig with inverter and a 12V "Lead acid minder" 50W setup.
The "ideal" would be to just connect that 50W panel with it's charge controller to the car via an ambilical.
The practical aspects of this however just didn't give me enough of a "Yes!" feeling to bother. I would cable that can carry at least 1A of current without more than 0.5V drop. It can get "slung" over the garage ceiling beams, but when it gets outside it has to be clipped into the wall above the door, back down and have somewhere to hang it up when not in use.
I suppose as an interim, I do have a 25m reel of 20AWG twin core. I can just drag it out of the garage when needed. Put some croc clips on the end of it.
I have to be some what "nasty" to the car and battery in coming months as a new job requires me to be in the office one or two days a week. That means the car gets abused with a 1 mile drive to the train station and another back in the evening, both cold starts in winter, not enough time to warm the car up (blue dash light still lit), not enough time to replace the cranking load in charge time either.
The new battery will be fine this winter while I sort something out. At £120 or so a pop 1 battery a year isn't 'that' bad, could be better. I could buy cheaper batteries, but having tried that already, they don't survive the first flattening, the premium brand batteries recover after mistakes better and will keep you going until you can source a new one. (Mine requires swapped posts which means you have to order it usually).
