Author Topic: constant current source design  (Read 4879 times)
Offline Jay_Diddy_B
Re: constant current source design
« Reply #25 on: June 04, 2019, 09:51:58 pm »
Hi Tom45 and the group,
The Vbe of the transistor has a temperature coefficient of -2mV per degree C.
The current will rise by about 2mV / Re, where Re is the emitter resistor.
Regards,
Jay_Diddy_B
Offline Arjunan M RTopic starter
  • Country: in
« Reply #26 on: June 05, 2019, 03:46:25 am »
Since you don't need much accuracy, why not just use a simple 1 transistor current sink.
The circuit below uses a 2N3904 and 3 resistors. Testing shows that it works down to 0.2 volts.
Current was about 1 ma at 0.2 volts, up to about 1.2 ma at 25 volts.
If you don't have 5 volts available, just recompute the base bias resistor divider for whatever voltage you do have.
NO I'm not using this circuit.Since I have to make the BOM as low as possible I will go with the other.
I'm not going to buy three different types of resistors.
In the other I only have to buy one type of resitor extra.49.9  \$\Omega\$\$\Omega\$.I already need 4K7.
Thanks for reply.
  • Country: in
« Reply #27 on: June 05, 2019, 03:49:55 am »
I don't need accuracy but the current has to constant as possible. Because I'm using an 18 bit ADC to measure current . I don't want to zero it out whenever i change the voltage.
