2. The 'ringing' shown by the oscilloscope and why the ringing changes with frequency.
The ringing is characteristic of that of a LC tank circuit -- i.e. an inductor in parallel with a capacitor.
This video at 1:17 does a pretty good job of explaining how the ringing is generated:
Oscillators, the Basic Tank Circuit 1
https://youtu.be/fQ4yRVEzXQA?t=1m17sEven though your circuit doesn't explicitly have a capacitor in parallel with your inductor there are other sources of capacitance such as:
- stray capacitance due to circuit layout (are you using a breadboard?)
- capacitance inherent to the inductor (parasitic capacitance)
- capacitance inherent to other components in the circuit (such as the transistor)
Here is a Falstad simulation of a LC-tank (with a damping resistor):
https://falstad.com/circuit/circuitjs.htmlYou can start the oscillations by momentarily closing and opening the switch (upper right corner of the schematic).
3. why reducing the 10K load to a 1k load reduced the output down to 6.4v.
The circuit works by periodically charging up the 47uF capacitor. Between these periodic charge-ups the load extracts current from the capacitor which reduces its voltage. A smaller valued resistor drains energy from a a capacitor faster than a larger valued resistor and so the average voltage of the cap between charge-ups will be smaller.
Note that even though "10K" is a larger number than "1K", we normally would say that a "10K load" is a smaller load than a "1K load" because it draws less current.
For more info look up "smoothing capacitor".
Here is a Falstad simulation of smoothing capacitor being charged up by a fullwave bridge rectifier:
(Falstad fullwave rectifier with smoothing cap)The graph on the bottom shows the voltage on the capacitor. Note how it decreases between charge-ups. The slope of the decrease depends on the load resistor.
