Author Topic: Inverting Negative Logic TTL To Positive With Discrete Transistors  (Read 6170 times)
Offline KJ-90Topic starter
I'm not sure if this is the right forum section to post this in, but I am wondering how to build a TTL compatible logic inverter from discrete components. Normally today, we use an IC for this task. However, I'm building a copy of a 1970s vintage TTL morse code generator, from the ( now defunct ) 73 Magazine, the design being from the February 1973 issue. The article is called "A TTL Logic CW ID Generator". This article is readily available online. Due to the circuit design, the morse code audio signal output of the circuit is produced as a negative logic signal. The circuit, which runs at a very low frequency ( below 5 Hz ), produces +5V when not generating a tone signal, and swings down close to 0V when generating tones. I know this is a strange way for the circuit to have been designed, but it is the original design. What I need to do is build a discrete transistor and component TTL-compatible inverter that converts the negative logic output to positive. In this way, the output is correct: +5V for tone signals, and close to 0V for no tone. You can assume the input to the inverter circuit is the output of only one standard 7400 "plain" TTL NAND gate, at below 5 Hz. The inverter would run on 5V, like the rest of the circuit. The output load of the inverter would be either a LED ( 1.8-2.2 Vf at 15mA ) or a small speaker. I'm not sure if a non-inverting buffer stage is needed after the inverter.
Although such circuits are very readily available online, my problem is that I don't know how to determine the required resistor values, for this application. Can someone point me towards a suitable circuit with suitable resistor values? I am building a discrete component inverter for an original period copy. In the original article, oddly enough, the author didn't provide a discrete inverter stage for positive logic output.  :-//
Offline danadak
Re: Inverting Negative Logic TTL To Positive With Discrete Transistors
« Reply #1 on: March 29, 2017, 11:15:02 am »
When driving an L load, like a relay, or speaker, use clamp diodes to
protect driver (D2 and D3 here, this is an example) -
Regards, Dana.
Offline kosine
« Reply #2 on: March 29, 2017, 03:05:59 pm »
A slightly oddball technique I've used in the past is a reverse mode transistor, specifically a 2N2222, although I think a BC547 will work as well.
Basically you wire it up backwards: collector to ground, emitter to 5V (through a suitable resistor). Your input just goes to the base.
You need to check whatever NPN transistor you use for the Vebo rating. Not all can handle 5V in reverse, but the 2222 and 547 can handle up to 6V, so they are OK.
Your output is from the emitter, and should be a clean 0V - 5V square wave at low frequency (I've used this trick up to 100kHz), duly inverted as required.
Because reverse mode has terrible gain, you may need to buffer the output through another transistor to power your LED or whatever. If you have a cheap multimeter with transistor test socket, you can check the gain - just reverse the C and E connections. It'll probably read about 5-10, but it will still work.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: March 29, 2017, 04:28:07 pm »
"Negative logic" implies negative voltage.  I think the word you are looking for is "active low"?
Active low is very traditional for TTL (all 74xx families except the CMOS ones), because the low state has a stronger output drive than the high state.  (And for CMOS, it's more symmetrical, but still has a stronger low state by about 50%.)
What logic ICs, exact part numbers, are used in the design?
Seven Transistor Labs, LLC
Online Zero999
  • 0999
« Reply #4 on: March 29, 2017, 05:10:16 pm »
That will work but why is it any better than configuring Q1 the 'correct' way round?
It's also missing a base resistor, unless the signal source already limits the current to a safe level.
Online ebastler
« Reply #5 on: March 29, 2017, 05:26:14 pm »
I can't seem to find it. Found a couple of recerences to it, but not the article itself. Could you post the link please?
EDIT: Found the original article here, p. 27: https://ia800803.us.archive.org/35/items/73-magazine-1973-02/02_February_1973.pdf
(Brace yourself for the cover page...)
I guess the author went with the inverted polarity simply because that's what he could create by making full use of the four NAND gates in the 7400 chip. In the spirit of the original design, you could simply replace the 7400 by a 74804 (six dual-input NAND gates, slightly exotic though), and use one of the two additional gates to invert the output. ;)
Another EDIT: Or you could ask the original designer for advice.  :)
Peter Stark is still around: http://www.users.cloud9.net/~pastark/
« Last Edit: March 29, 2017, 05:46:22 pm by ebastler »
Offline Dinsdale
    • pretzelogic
« Reply #6 on: March 30, 2017, 02:37:20 am »
I searched for ECL to further emphasize this fact.  I was dismayed to see no mention if "negative logic" in the Wikipedia article.
I went to Wikipedia page for "negative logic". It only mentions topics of "logic level" and "negation".
The world is really getting to be a f*cked up place.
This can't be happening.
Offline edavid
« Reply #7 on: March 30, 2017, 03:23:35 am »
It does not.
positive logic: logic 1 = nearer to supply voltage, logic 0 = nearer to ground
negative logic: logic 1 = nearer to ground, logic 0 = nearer to supply voltage
If you are drawing 7400 gates as NANDs, you are using positive logic.
If you are drawing them as NORs, you are using negative logic.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #8 on: March 30, 2017, 10:43:23 am »
It does not.
if that is the case, then whats wrong with this, or that? (attached 2 circuits)
Offline kosine
« Reply #9 on: March 30, 2017, 11:12:37 am »
Hero999 is correct: I should have added a base resistor (maybe 10k).
In this particular case, running Q1 in forward mode would work OK, but for other applications that's not a given.
I ran into the issue when trying to convert a 1.5V 9600 baud serial link to 5V. (It was the output from one of those cheap digital calipers.) Forward mode simply didn't work - the output was not even close to a 0V-5V square wave. I got a sequence of exponential charging curves instead, and not rail-to-rail either. A cascode and discrete Schmitt trigger both worked better, but didn't completely solve the problem, whereas simply reversing the input transistor did.
The problem was likely due to the source output impedance, which I reckon was 100k or more. Too little input current to adequately charge the transistor I think. (Reducing the gain also reduces the capacitance seen by the source.) You shouldn't have that problem with a TTL source, but reverse mode is one of those simple tricks that come in handy on occasion, so I thought I'd mention it as a possible solution.
Offline edavid
« Reply #10 on: March 30, 2017, 03:27:50 pm »
They are fine, depending on what the load actually is.  The whole "negative logic" thing was a red herring.
What I don't understand is why the OP insisted on a discrete stage, instead of just hooking up another 7400 or 7404.
