Author Topic: learning how to use my Rigol DS1104Z's features, need help  (Read 739 times)
Offline jpyeronTopic starter
    • PD Inc
« on: November 24, 2019, 04:06:05 am »
I am trying to reverse engineer a communications protocol between two black boxes.
The reader has an inductive coil and the sensor has a mating coil. I have put a man in the middle coil circuit, and the reader communicates with the sensor successfully.
It appears as a 7kHz 34V peak to peak sine wave, sampled as show here: 877574-0. The communications start after pressing the trigger and last less than 5 seconds (having trouble getting an exact timing).
I tried the record feature, but captures way too little (2 frames), so I know I am doing something wrong.
« Last Edit: November 24, 2019, 06:19:22 am by jpyeron »
    • PD Inc
Re: learning how to use my Rigol DS1104Z's features, need help
« Reply #1 on: November 24, 2019, 05:12:04 am »
I am assuming that I will see something like: .
I am looking to trigger continuous recording, until memory is exhausted and after the first trigger event.
The whole signal is about a second long.
100us per div https://youtu.be/at8rgkf5-hs?t=4
20us per div https://youtu.be/at8rgkf5-hs?t=17
« Last Edit: November 24, 2019, 05:35:01 pm by jpyeron »
    • PD Inc
« Reply #2 on: November 24, 2019, 05:56:44 pm »
Solved it - Roll mode - page 63 of the manual
