I am trying to reverse engineer a communications protocol between two black boxes.
The reader has an inductive coil and the sensor has a mating coil. I have put a man in the middle coil circuit, and the reader communicates with the sensor successfully.
It appears as a 7kHz 34V peak to peak sine wave, sampled as show here: [attach=1]. The communications start after pressing the trigger and last less than 5 seconds (having trouble getting an exact timing).
I tried the record feature, but captures way too little (2 frames), so I know I am doing something wrong.
