Hi All,
I'm getting quite frustrated that I'm not getting the kind of results I was hoping for with this new CREE. So I've been trying various PSU's. The built in one I tweaked up to about 12.7V, which when loaded is dropping to about 12.55V.
The current flow I'm getting is just above the 1A mark.
Other PSU's I've tried is a 12V 2.5A, and even a 12V 10A. The second one is far beyond the need, but based on the character graph I'm thinking it should be drawing around 1.5A, and yet I'm getting a measly 900mA. The 10A PSU was measured at 12.05V under load, and 12.6V when unloaded.
Am I measuring wrong, is my meter not giving me accurate enough results? My meter is a UNI-T UT139C
I understand that using a Constant Current driver would be ideal, but it must have PWM input, and I'm only finding ones that are capable of 700mA - I'm after around the 2A mark.
I just don't know where to look. Even better, has anybody had any experience with these XHP70 LED modules?
As a side note, I've just checked the power draw from the main socket to be only 13.5W. That was driving the LED directly from the 12V 2.5A PSU.
Thanks, James
