Author Topic: Assembly, Atmega 328 PWM, phase correct mode - out of range problem  (Read 424 times)
Offline MikeliniusTopic starter
I'm new into assembly and I need to generate in PWM, phase correct mode signal with frequency 255 Hz and FF 55 % but I have problem with Atmega328 - you can see in the screen what is wrong. But what's more - my code works for Atmega32. It looks like I use some kind of bad instruction, but I've no idea what exactly is wrong. Do you have any idea what's wrong?
.include"m328def.inc"
SBI DDRB, 3
LDI R16, 140 // Fill factor 140/255 = 55%
OUT OCR2A, R16
LDI R17, 0b00000001 //PWM PC
out TCCR2A, R17
LDI R18, 0b00000101 //prescaler 128
out TCCR2B, R17
loop:
rjmp loop
« Last Edit: January 20, 2022, 05:58:33 pm by Mikelinius »
Offline Kleinstein
Re: Assembly, Atmega 328 PWM, phase correct mode - out of range problem
« Reply #1 on: January 20, 2022, 05:43:13 pm »
The newer Megaxx8 have many of the registers at different locations and some of the timers get out of the range of the OUT instruction. So one would need to use STS instead.
For some reason they had (not sure if fixed) some of the examples in the datasheet also wrong in this aspect.
Some of register names also changes, though to a large part same funtionality as the mega32.
The following users thanked this post: Mikelinius
Offline Skashkash
« Reply #2 on: January 20, 2022, 05:49:05 pm »
Was about to say exactly the same.
I've taken to using the following macros so I don't have to keep track of the register address.
(These may not be appropriate for the more modern chips or newer versions of studio.)
;--- in for any port address
.macro   in_reg
.if    @1<0x40
    in @0,@1
.else
    lds @0,@1
.endif
.endm
;--- out for any port address
.macro   out_reg
.if @0<0x40
out @0,@1
.else
    sts @0,@1
.endif
.endm
