The output voltage isn't likely to climb above the 12.60 Volts, the no load voltage. My intended load will function from anywhere between 11.40 Volts and 14.40 Volts. The AC mains input on the primary side will fluctuate I've no doubt about that, also the transformers secondary side AC output will also fluctuate. But the margin between the rectified filtered voltage and the regulators output is reasonable, not perfect, but ok. The load current will be just shy of 8 Amps, and an approximation of a 50% duty cycle is fairly typical with HF linear amplifiers. So it should be ok i think, i have three other projects very similar, but those will run 6 x power transistors. And i would like to try and reach a target voltage of 13.20 Volts, or close to it. But i will probably use darlington transistors, i have used them before with good results. The two transformers in the psu above are right at about the limit of current i would want to draw from them. The 12 Amps might as well be a peak maximum, i'm unlikely to hit that much current with a HF 100 watt linear amplifier with a 4 watt drive into it, there are always losses in these mosfet driven amplifiers. The manufacturers always hype up the specs. In reality i expect it will deliver between 75 to 85 Watts after losses, but that's fine.
