Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
LED lighting ideas for a project wanted
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LED lighting ideas for a project wanted (Read 719 times)
jonwil
Contributor
on:
April 04, 2019, 11:03:32 am »
Apologies if this is wrong forum, if it is can someone please point me to the right one?
I am currently building a model of the Castlemaine Perkins Brewery out of LEGO bricks and I want to re-create the light up sequence XXXX sign on the roof as seen here
http://cometravellingwithus.blogspot.com/2012/08/xxxx-brewery-tour-look-listen-learnthen.html
Can anyone out there suggest what sort of LEDs or lighting system (and what sort of control board) I should consider using for the lights? And what might work for the X's themselves (LEGO makes lights but nothing that would work for this).
Looking for something that can be powered from standard AA/AAA batteries (I can hide the batteries and control logic easily enough) and I intend the Xs to be about 2cm high or so to fit with the scale of the building. I hope someone can point me in the right direction.
Logged
soldar
Super Contributor
Country:
Re: LED lighting ideas for a project wanted
Reply #1 on:
April 04, 2019, 12:38:56 pm »
You could make the X directly with several SMD LEDs but it might be simpler for you to use just a couple regular, discrete LEDs behind a translucent plastic.
Logged
Nusa
Super Contributor
Country:
Reply #2 on:
April 04, 2019, 12:59:57 pm »
COB filament LED's are about the right size for the diagonals for DIY letters. You would need 2 of them for each X. You should be able to adjust the voltage to get the brightness you desire.
https://www.aliexpress.com/item/5Pcs-Set-COB-LED-1W-Filament-Bulb-DC2-9-3-1V-130LM-Candle-Light-Source-Accessaries/32892399508.html
Logged
jonwil
Contributor
Reply #3 on:
April 04, 2019, 08:12:48 pm »
Anyone got any ideas for how to control this? As a programmer my gut says one of those cheap small microcontroller boards makes sense...
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
