Hello
I wanted a PCB with 20 CLQ6B-TKW RGBW Leds with 48VDC power supply.
I do not want a voltage boost led driver. It has to be a set-down Buck converter (4 actually). One for each color + white, but as you know 48VDC is not enough.
So the solution would be to parallelize the LEDs, 2 parallel string of 10LEDs @0.2mA for each led driver.
Since every LED has a different forward voltage, will it be a problem???
I mean 10 LEDs in series, statistically, I would say the 2 string will have approximately the same voltage drop, no?
Or will I need to measure the forward voltage of each LED, an select the right ones to create a balanced strings?
