Author Topic: Variable low voltage AC supply  (Read 2739 times)
Offline drakkeTopic starter
« on: March 31, 2015, 03:28:02 am »
There are a lot of DC lab powers supply design circuits (AC to DC conversion) but how do you experiment with them when you don't have any safe AC supply?
I have been looking for a variable AC supply but there are very few compared to DC supplies. I suppose I don't need 120v but possible 0-24v at 50-60Hz.
I want to be very safe. What are the options?
Thanks.
Offline AG6QR
    • AG6QR Blog
Re: Variable low voltage AC supply
« Reply #1 on: March 31, 2015, 03:58:38 am »
A Variac (common brand name for a variable autotransformer) is a way of providing an adjustable AC voltage from mains.  Usually, they go from near-zero to about 120% of the supply voltage, or thereabouts.  Normally, you plug it straight into the mains, but if you plugged one into a step-down transformer with a 24VAC output, the output of your Variac would be capable of about 0 to 26 VAC, or thereabouts.  A Variac has a current limit, which must not be exceeded, neither on the input side nor on the output side, so beware of this.
Or you could use a function generator, perhaps followed by a buffer amplifier.  That would give you flexibility in frequency as well as voltage.
Online edpalmer42
« Reply #2 on: March 31, 2015, 04:26:42 am »
Model train transformers have an isolated AC output of up to 20V or so.  Power rating can be as high as 50 - 100 watts.
Ed
Offline 3roomlab
« Reply #3 on: March 31, 2015, 08:20:04 am »
a 50/60Hz signal generator + a small audio power amplifier (maybe car amplifier?) or even just a DIY BJT/MOSFET module?
« Reply #4 on: April 05, 2015, 06:38:18 am »
Is this another possibility?
Class 2 Plug-in Transformer 120VAC - 24VAC
http://www.mroelectronics.com/mro/product.php?id_product=4793
... then wire the output terminals of the transformer to the binding posts on my breadboard.
Offline Zero999
  • 0999
« Reply #5 on: April 05, 2015, 08:39:05 am »
That's a transformer which outputs a fixed voltage. The original poster wanted a variable transformer.
