Hi guys, been a while.
So I'll try cut a long story short. Or not...
A few months back I bought a 30 RGB LED Strip PCB. I've been running each channel off a TIP-120 Transistor, controlled by the PWM output of an Arduino, and I programmed a C# application so I'd get all sorts of colourful pulsed alerts for things like email/windows alerts and music rainbow pulsing stuff while playing audio. That was really cool.
Anyway, I had this thing running off a 2A Molex power supply I had lying around, it was one of those ones for powering an external HDD, came with the IDE to USB thing as well. Today I made some modifications to it, I added a gel battery, outdoor solar panel with built in trickle charge and a spdt relay so it can basically turn on if mains fails by itself, and stores the 'on' state in eeprom.
I've put it all up on the ceiling, and stupidly didn't even measure how much current this thing draws and just assumed 2A was plenty. I had an issue where if I simulated a power failure by unplugging the mains and then plugging it back in, when the relay coil activated and the Arduino turned on, which also instantly turned on the LED strip, the coil couldn't sustain its magnetic field I guess? Anyway, it cut out, and then basically loops continuously trying to turn on and loosing power.
I wanted to know if leds can have a large surge current, or am I borderline on the power supply? I fixed the issue perfectly by adding a 2 seconds delay before the Arduino activates the lights, but I don't know if it's safe. I'd rather not pull the strip down to measure the current. I've found that some super bright white leds can draw 20ma, which I think is the most power hungry led variant, and this has 30r, 30g and 30b. Assuming they took 20ma each that's 1.8a, the relay coil takes 200ma. So... That's conveniently 2A.
Don't know what to do. Pull it down and test it? Do leds even have a surge current? I doubt each led on the strip would draw 60ma max? Can a small wall transformer be dangerous if it's overloaded?
Thanks
