Author Topic: Voltage drop across fuse - what to expect?  (Read 4033 times)
Offline FlashEFTopic starter
« on: August 03, 2012, 03:37:28 pm »
I'd like to use a fuse in an circuit powering a mobile robot (MicroMouse) from a LiPol battery. The fuse is going to be a protection device in case of a hard short of power lines, in order not to blow up the battery (which has no protection what so ever - its an RC hobby battery).
Fuse name:
Littelfuse 0154005.DR
Datasheet:
http://www.littelfuse.com/data/en/Data_Sheets/Littelfuse_fuseblocks_154_155.pdf
There is nothing about resistance/voltage drop of this fuse. Is is supposed to be so insignificant? My battery nominally has 7,4V so say half a volt of drop on the fuse would be really much.
Offline Short Circuit
    • White Bream electronics R&D
Re: Voltage drop across fuse - what to expect?
« Reply #1 on: August 03, 2012, 03:48:56 pm »
Look for the datasheet of the furnised fuse. That contains additional data, including "nominal resistance, cold ohms".
« Reply #2 on: August 03, 2012, 04:40:57 pm »
Thaks - knowing what to search it was easy to find. It has cold ohms specified in the fuse family data:
http://www.littelfuse.com/products/fuse-blocks-fuseholders-and-fuse-accessories/fuse-blocks/154/0154005_drt.aspx
For this particular one cold ohms are: 0.0136R. So the voltage drop should be really in the millivolt range.
