Hello everyone, I've been looking through some LED datasheets and I have seen in many that the LEDs should not be used below 5mA to 10mA depending on manufacturers. Does anyone know what is the reason for this?
Important to note this isn't a dinkly little If=20mA indicator LED, but a power lighting LED with typical If=120mA. Look at the relative intensity curve on page 13 (reproduced below), and notice that the intensity curve on the Y-axis disappears right around where 5 mA would be on the X-axis. So Osram is saying that
typically this LED will have no effective output below If=5mA.
Edit: our regular If=20mA LEDs will happily emit light visible to the naked eye down to at least 0.5-1mA in my experience
BTW, dimming lighting LEDs in general is more commonly done with PWM rather than a linear constant current driver.
