Author Topic: LM358 amplifier circuit  (Read 1373 times)
Offline cosminnciTopic starter
« on: September 30, 2014, 10:31:17 am »
Hello,
I want to make an ir barrier used indoors with a tv set close by.
I tought of a tsop but there might be conflicts with the tv remote, so I tought of making it with sfh300 phototransistor.
the distance between ir led and receiver should be 1m.
I found a schematic the one attached, but it does not give the range.
I generate a 1khz pulse with an arduino and at about 10cm it starts to narrow the pulse then rounds the falling edge and the signal dissapears.
what could I do to improve the sensitivity?
Online T3sl4co1l
    • Seven Transistor Labs
Re: LM358 amplifier circuit
« Reply #1 on: September 30, 2014, 07:53:50 pm »
IC1 inputs are reversed.
Seven Transistor Labs, LLC
