Author Topic: Li-ion nominal voltage, why so low?  (Read 2304 times)
Offline jsavukoskiTopic starter
« on: November 08, 2017, 09:52:55 pm »
Can someone shed a light on why the li-ion nominal cell voltage is only 3.6/3.7 and not higher? I'm just puffing here with my e-cig and wondering how much more efficient (FET driving, conductor losses -wise) it would be if the single cell voltage would be higher.
Is it a compromise with power density? Higher voltage would decrease that? Or something to do with chemistry? In some “natural” (compact) configuration you just happen to get that nominal voltage?
And, yea, no series-cells battery configurations yet for these compact devices; balance charging is a bit of a pita.
-Janne
Online IanB
Re: Li-ion nominal voltage, why so low?
« Reply #1 on: November 08, 2017, 09:58:42 pm »
-Janne
This question comes up from time to time, but the answer is simple. The voltage of a cell is governed by chemistry: by the electrode materials and the electrolyte. There is no free choice about what it is. It is fixed and immutable.
The following users thanked this post: 001
Offline danadak
Offline Belrmar
« Reply #3 on: November 08, 2017, 10:30:30 pm »
The nominal voltage of a LI-ion is governed by chemistry, we are not chemists but ee's so we can f*** ourselves and use cells on series  |O lipo cells are compact enough to use them in series , but the balancing circuitry is annoying
Offline Audioguru
« Reply #4 on: November 09, 2017, 01:04:06 am »
A normal Lithium Ion cell is fully charged at 4.2V, is 3.7V at half a discharge and is about 3.2V when almost dead. If it discharged lower than 3.2V then it is destroyed. If it is charged higher than 4.2V then it might blow up and/or catch on fire.
Online sleemanj
  • Professional tightwad.
« Reply #5 on: November 09, 2017, 01:45:43 am »
Maybe in the dim dark ages, but I will happily take any of your "destroyed" lithium ion cells if you are throwing them out at under 3.2v!
Even datashsets state the discharge voltage way less than that for typical cells.
Offline james_s
« Reply #6 on: November 10, 2017, 07:58:08 pm »
There is also resting voltage vs voltage under load. At least with the high current LiPos I use in RC aircraft it is generally not advised to run them down below about 3.4V/cell. Doing so causes them to degrade faster, if you only discharge about 80% of the capacity they will last longer.
Offline metrologist
« Reply #7 on: November 10, 2017, 08:06:51 pm »
This is good post for some questions I had about # of charge cycles for li-ion . I think I read that if you don't discharge below 90%, then that is not considered a cycle, and that if you don't discharge below what's been stated, you can 3-4x times the number of cycles. So I guess I should plug my phone in more often and charge up my ebike after every ride.
Offline Mjolinor
« Reply #8 on: November 10, 2017, 08:28:21 pm »
Best not guessing and go looking for the truth on t'Interweb.
I run my phone 80% to 40% when ever I can.
