Electronics => Beginners => Topic started by: DanioIO on August 31, 2014, 05:23:17 pm
I have a couple of ADP5063 ic and i want to make a charger for my Li-Pol batteries can i use this ic safely? I will need to change the charging termination voltage to 4.2V but this ic allows it so are there any other stuff to consider?
ADP5063 datasheet (http://www.analog.com/static/imported-files/data_sheets/ADP5063.pdf (http://www.analog.com/static/imported-files/data_sheets/ADP5063.pdf))
Interesting chip.
I'm just learning about this stuff myself. The thing that caught my eye is that you'll probably want to adjust the current thresholds for Iend. I think the typical guidance is to terminate charging when current drops to 1/10th of the constant-current phase charging rate. It looks like this chip configures those parameters independently from each other, and the default termination current is less than 10% of the default CC rate.
Hmm, now im thinking about blowing a Li-Pol battery with this ic i wonder if its possible...
