Author Topic: [SOLVED] [MSP430F5529 + ili9341 screen] command instruction seem don't works  (Read 504 times)
Offline OrKarazTopic starter
Since few days i'm working on a screen project with my MSP430F5529 and one ili9341 screen.
I have take an exemple (from arduino, can't find on MSP) and adapt it to know how use the screen.
After few try, i can fill the screen with colors but can't draw a simple line or rectangle at a special position.
When i run the program step by step, all instruction command work and on the screen i have all the program what have to do.
I have try to change all wire but no change.
The MSP430F5529 run at 25 MHz (max) with 3.3V like the screen.
//This application does not rely on any libraries and it is for ILI9341
//This program is a demo of clearing screen to display black,white,red,green,blue.
//when using the BREAKOUT BOARD only and using these hardware spi lines to the LCD,
//the SDA pin and SCK pin is defined by the system and can't be modified.
//if you don't need to control the LED pin,you can set it to 3.3V and set the pin definition to -1.
//other pins can be defined by youself,for example
//pin usage as follow:
//             CS  DC/RS  RESET  SDI/MOSI  SCK   LED    VCC     GND
//                                                              GND
//Remember to set the pins to suit your display module!
#include <msp430.h>
#define FPROC 25000000
P3.0 : MOSI
P3.1 : MISO
P3.2 : CLK
#define RSUP        P6OUT|=BIT0    // DC/RS
#define RSDOWN      P6OUT&=~BIT0
#define LEDUP       P6OUT|=BIT1
#define LEDDOWN     P6OUT&=~BIT1
#define CSUP        P6OUT|=BIT2
#define CSDOWN      P6OUT&=~BIT2
#define RESETUP     P6OUT|=BIT3
#define RESETDOWN   P6OUT&=~BIT3
unsigned long oldrand = 5468;
void SetVcoreUp (unsigned int level)
  // Open PMM registers for write
  PMMCTL0_H = PMMPW_H;
  // Set SVS/SVM high side new level
  SVSMHCTL = SVSHE + SVSHRVL0 * level + SVMHE + SVSMHRRL0 * level;
  // Set SVM low side to new level
  SVSMLCTL = SVSLE + SVMLE + SVSMLRRL0 * level;
  // Wait till SVM is settled
  while ((PMMIFG & SVSMLDLYIFG) == 0);
  // Clear already set flags
  PMMIFG &= ~(SVMLVLRIFG + SVMLIFG);
  // Set VCore to new level
  PMMCTL0_L = PMMCOREV0 * level;
  // Wait till new level reached
  if ((PMMIFG & SVMLIFG))
    while ((PMMIFG & SVMLVLRIFG) == 0);
  // Set SVS/SVM low side to new level
  SVSMLCTL = SVSLE + SVSLRVL0 * level + SVMLE + SVSMLRRL0 * level;
  // Lock PMM registers for write access
  PMMCTL0_H = 0x00;
// fonction aleatoire
unsigned int random(unsigned int n) {
    unsigned long nn = oldrand;
    oldrand = (unsigned int)((859*nn)%6823);
    return oldrand % n;
void delay(unsigned int i){
    while(i--)
        __delay_cycles(FPROC/1000);  // 1000 for 1MHz
// envoyer sur le SPI la donnée
void Lcd_Writ_Bus(unsigned char d)
    while(UCB0STAT&BIT0) {} // si la communication n'est pas finie on attend
    UCB0TXBUF = d;
// écrire la commande
void Lcd_Write_Com(unsigned char VH)
  RSDOWN; //LCD_RS=0;
  Lcd_Writ_Bus(VH);
// écrire la donnée
void Lcd_Write_Data(unsigned char VH)
  RSUP; //LCD_RS=1;
  Lcd_Writ_Bus(VH);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
    Lcd_Write_Com(0x2a);
Lcd_Write_Data(x1>>8);
Lcd_Write_Data(x1);
Lcd_Write_Data(x2>>8);
Lcd_Write_Data(x2);
    Lcd_Write_Com(0x2b);
Lcd_Write_Data(y1>>8);
Lcd_Write_Data(y1);
Lcd_Write_Data(y2>>8);
Lcd_Write_Data(y2);
    Lcd_Write_Com(0x2c);
void draw_pixel (unsigned char cr,unsigned char cv,unsigned char cb) {
    Lcd_Write_Data(cr);
    Lcd_Write_Data(cv);
    Lcd_Write_Data(cb);
void SPI_Init(void)
    UCB0CTL0 = BIT7 | BIT5 | BIT3; // Master + MSBfirst + front montant + CLK inactif 0
    UCB0CTL1 = BIT7 | BIT6; // SMCLK
    P3SEL |= 0x07; // on utilise le SPI (CLK, MOSI et MISO)
void Lcd_Init(void)
    RESETUP;
    delay(5);
    RESETDOWN;
    delay(15);
    RESETUP;
    delay(15);
    CSDOWN;  //CS
    Lcd_Write_Com(0xCB);
    Lcd_Write_Data(0x39);
    Lcd_Write_Data(0x2C);
    Lcd_Write_Data(0x00);
    Lcd_Write_Data(0x34);
    Lcd_Write_Data(0x02);
    Lcd_Write_Com(0xCF);
    Lcd_Write_Data(0XC1);
    Lcd_Write_Data(0X30);
    Lcd_Write_Com(0xE8);
    Lcd_Write_Data(0x85);
    Lcd_Write_Data(0x78);
    Lcd_Write_Com(0xEA);
    Lcd_Write_Com(0xED);
    Lcd_Write_Data(0x64);
    Lcd_Write_Data(0x03);
    Lcd_Write_Data(0X12);
    Lcd_Write_Data(0X81);
    Lcd_Write_Com(0xF7);
    Lcd_Write_Data(0x20);
    Lcd_Write_Com(0xC0);    //Power control
    Lcd_Write_Data(0x23);   // 23 VRH[5:0]
    Lcd_Write_Com(0xC1);    //Power control
    Lcd_Write_Data(0x10);   //SAP[2:0];BT[3:0]
    Lcd_Write_Com(0xC5);    //VCM control
    Lcd_Write_Data(0x3e);   //Contrast
    Lcd_Write_Data(0x28);
    Lcd_Write_Com(0xC7);    //VCM control2
    Lcd_Write_Data(0x86);   //--
    Lcd_Write_Com(0x36);    // Memory Access Control
    Lcd_Write_Data(0x48);   // 48    (28 -> mode paysage, 48 -> mode portrait)
    Lcd_Write_Com(0x3A);  // Pixel format set
    Lcd_Write_Data(0x66); // 55
    Lcd_Write_Com(0xB1);
    Lcd_Write_Data(0x18); // 18
    Lcd_Write_Com(0xB6);    // Display Function Control
    Lcd_Write_Data(0x08);
    Lcd_Write_Data(0x82); // 82
    Lcd_Write_Data(0x27);
    Lcd_Write_Com(0x11);    //Exit Sleep
    delay(120);
    Lcd_Write_Com(0x29);    //Display on
    CSUP;
void H_line(unsigned int x, unsigned int y, unsigned int l,unsigned char cr,unsigned char cv,unsigned char cb)
    unsigned int i;
    CSDOWN;
    Lcd_Write_Com(0x02c); //write_memory_start
    Address_set(x,y,l+x,y);
    for(i=1;i<=l;i++)
        draw_pixel(cr, cv, cb);
    CSUP;
void V_line(unsigned int x, unsigned int y, unsigned int l,unsigned char cr,unsigned char cv,unsigned char cb)
  unsigned int i;
  CSDOWN;
  Address_set(x,y,x,l+y);
  for(i=1;i<=l;i++)
  CSUP;
void Rect(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned char cr,unsigned char cv,unsigned char cb)
  H_line(x  , y  , w, cr, cv, cb);
  H_line(x  , y+h, w, cr, cv, cb);
  V_line(x  , y  , h, cr, cv, cb);
  V_line(x+w, y  , h, cr, cv, cb);
void Rectf(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned char cr,unsigned char cv,unsigned char cb)
  unsigned int i;
  for(i=0;i<h;i++)
    H_line(x  , y+i, w, cr, cv, cb);
void LCD_Clear(unsigned char cr,unsigned char cv,unsigned char cb)
  unsigned int ii,mm;
  CSDOWN;
  Address_set(0,0,240,320);
  for(ii=0;ii<240;ii++)
    for(mm=0;mm<320;mm++)
  CSUP;
void LCD_Arc()
    unsigned int ii,mm;
    unsigned char cb = 0, cv = 0, cr = 0;
    CSDOWN;
    for(ii=0;ii<320;ii++) {
        if (ii<80) cr=3*(ii%80);
        else if (ii<160) cr=3*(80-(ii-80)%80);
        else if (ii<240) cb=3*((ii-160)%80);
        else cb=3*(80-(ii-240)%80);
        for(mm=0;mm<240;mm++)
            cv = mm%240;
    CSUP;
void LCD_Carre()
    unsigned int ii;
    CSDOWN;
    Address_set(10,10,20,20);
    for(ii=0;ii<100;ii++) {
      draw_pixel(0xff, 0xff, 0xff);
    CSUP;
 * main.c
void main(void)
    WDTCTL = WDTPW | WDTHOLD; // stop watchdog timer
    SetVcoreUp(1);
    SetVcoreUp(2);
    SetVcoreUp(3);
    UCSCTL3 |= SELREF_2;                      // Set DCO FLL reference = REFO (32 768)
    __bis_SR_register(SCG0);                  // Disable the FLL control loop
    UCSCTL0 = 0x0000;                         // Set lowest possible DCOx, MODx
    UCSCTL1 = DCORSEL_5;                      // Select DCO range 25MHz operation
    UCSCTL2 = FLLD_0 + (FPROC/32768 - 1);     // Set DCO Multiplier for 25MHz (487 pour 16MHz) (761 pour 25MHz)
                                              // (N + 1) * FLLRef = Fdco
                                              // (761 + 1) * 32768 = 25MHz
                                              // Set FLL Div = fDCOCLK
    __bic_SR_register(SCG0);                  // Enable the FLL control loopthen select clock source by write SPI control register (UCSSELx)
    UCSCTL4 |= SELA_3;                  // présence de MCLK/1024 sur P1.0
    UCSCTL5 |= DIVPA_5 | DIVA_5;
    P1DIR |= BIT0;
    P1SEL |= BIT0;
    SPI_Init();
    P6DIR |= 0x0F; // bit0 à 3 en sortie
    RSUP;
    LEDUP;
    CSUP;
    RESETUP;
    Lcd_Init();
    while (1) {
        LCD_Clear(0xff, 0xff, 0xff);
        delay(1000);
        LCD_Clear(0xff, 0x00, 0x00);
        delay(1000);
        LCD_Clear(0x00, 0xff, 0x00);
        delay(1000);
        LCD_Clear(0x00, 0x00, 0xff);
        delay(1000);
        LCD_Arc();
        delay(3000);
        LCD_Carre();
        delay(5000);
        LCD_Clear(0x00, 0x00, 0x00);
        Rect(10,10,100,50,random(256),random(256),random(256));
        /*for(i=0;i<100;i++)
            Rect(random(239),random(319),random(239),random(319),random(256),random(256),random(256)); // rectangle at x, y, width, hight, color
        delay(5000);
__bis_SR_register(LPM4_bits);
Thank you for help.
« Last Edit: January 21, 2021, 01:20:51 pm by OrKaraz »
Offline mayor
Re: [MSP430F5529 + ili9341 screen] command instruction seem don't works
« Reply #1 on: January 21, 2021, 11:53:18 am »
Pasting the entire program makes it difficult to help. Can you paste a minimal working example (filling the screen), and a minimal non-working example (a line) ?
« Reply #2 on: January 21, 2021, 01:20:32 pm »
All the program is minimum.
After more research when waiting this answer (16h i search it) i have find the probem.
To me : never use any more --opt_level 3 or 4.
Don't know why, but the "P6OUT &= ~BIT0" instruction was not working in --opt_level 4 nether 3. (line 84)
I have set to 2 and now all works like it does to be.
Now i'll able to use ASM.
Thank you for answering.
