Installed a brand new Broan Allure QS1 series range hood in my kitchen, all went fine and we are happy with it. The instructions calls for two PAR20 50W max Halogen bulbs and the unit has a 3 position rocker switch to control the intensity (Low, OFF, High). It also has a second similar switch for the fan speed (Low, OFF, High)
Since PAR20 50W bulbs were also available in dimmable LED I decided to install them instead of the Halogen because the LED’s remain cool to the touch. However the rocker switch has no effect on the lights intensity, having the switch in the Low or high position the light intensity remains the same.
Is it because I do need to install Halogen bulbs?
Perhaps if I install non dimmable LED’s?
Thank you
