Once again: please do not spread post content across multiple services. If it’s your own work, the forum provides an option to attach images (below the message body editor). In the case of your last post you even used a wrong URL, so most people aren’t even aware there is any image.
I am still missing a complete picture of the situation, so I will be making some guesses. Corrent me, if I am wrong. You have a remote for a garage door opener. Both the door opener and the remote are acting as black boxes. You want to replace the remote. The opener provides power and receives (but doesn’t send) data. You still didn’t say, what are requirements of your device, which is what I asked about. So, once again: what does your device require to run? ESP32-C3-MINI requires 500 mA minimum (
IVDD, tab. 4.2, p. 14), based on the datasheet. That’s over ten times more than values mentioned so far and also over maximum current from BD9G101G (
IOUT, p. 5). Do you have any information, if there are pull-up resistors present in the original devices (and which one)? How much current is the original pilot drawing?
As for the rest: 12 V / 45 mA ≈ 267 Ω. The wire can’t be causing the drop, unless you run it across a town.
(1) Your description resembles more source’s internal resistance (if the voltage falls to 0 smoothly) or an overcurrent or thermal protection kicking in (if it falls abruptly). In the former case it may not be possible to draw current that high continuously.
As for a 1/4 W resistor being sufficient: without knowing the details it’s hard to tell with any certainity. It may and,
with the original assumptions it sounds plausible. The point was that a 1 W rated resistor is not needed, because it’s just a short, rarely occuring burst of high current. As for using 0805: I have no opinion or practical experience with how these handle exceeding limits.
(1) See tab. 10 (p. 23) in
Copper Wire Tables (1966) from National Bureau of Standards (
archive.org), or
p. 27 in the 1914 release.
