Author Topic: Frequency doubling at 1MHz using AD633 multiplier  (Read 1351 times)
Offline FizdizTopic starter
« on: November 30, 2020, 05:26:22 pm »
Hello,
I have a question on the AD633 multiplier, which I'm using as a squarer and with which I'm supposed to see frequency doubling for a sine wave input.
But at a frequency of ≥1MHz, the output is heavily distorted (looks like a sawtooth wave and heavily attenuated) and its frequency is about the same as the input frequency (i.e. no frequency doubling is seen).
I know that one should see attenuation at very high input frequencies (due to the op-amp gain roll-over) but I wouldn't know why frequency doubling is not observed anymore.
Any ideas on why this is would be highly appreciated :)
Here is the data sheet for the AD633:
https://www.analog.com/media/en/technical-documentation/data-sheets/AD633.pdf
Offline Paul Rose
Re: Frequency doubling at 1MHz using AD633 multiplier
« Reply #1 on: November 30, 2020, 08:59:19 pm »
Maybe see the graph at Figure 9 of that data sheet: "AC Feedthrough vs Frequency"
The X and Y feedthrough peak pretty strongly at 1Mhz (and that's on a graph with logarithmic axis).
Maybe your inputs are swamping your intended output.
« Reply #2 on: December 01, 2020, 06:12:32 pm »
Thanks, that makes a lot of sense!
Online David Hess
  • DavidH
« Reply #3 on: December 01, 2020, 09:56:58 pm »
The AD633 is just not suitable for operation at that frequency.  You would do much better with a Gilbert cell even made with discrete transistors.
Offline Paul Rose
« Reply #4 on: December 02, 2020, 12:03:29 am »
I kind of miss the CA3054 transistor array.
6 transistors pre-connected just right for making a gilbert cell, but allowing you to bias how you want.
Online David Hess
  • DavidH
« Reply #5 on: December 02, 2020, 03:18:58 am »
Many of the early Tektronix custom ICs were specialized versions of the CA3054, and this is why their 2213/2215 series of oscilloscopes could use the CA series transistor arrays instead of custom Tektronix ICs.
« Reply #6 on: December 06, 2020, 11:45:52 pm »
I've got another question, for the same circuit (i.e. sine wave input on both AD633 inputs, but this time at 1kHz).
When I calculate the scale factor from the input and output signals of the AD633 (which should be 1/(10V)), I get a much lower value when the input is only positive than when the input is only negative. (Scale factor when input is positive: 9.8, scale factor when input is negative: 9.9)
Is there a possible reason that the AD633 behaves differently for positive or negative inputs? (Note: the Ad633 is used as a squarer so both inputs are always on the same voltage).
Online David Hess
  • DavidH
« Reply #7 on: December 07, 2020, 04:38:13 pm »
That difference is within the 1% error from nonlinearity.  Be sure to adjust the offset first.
« Reply #8 on: December 07, 2020, 09:50:17 pm »
Thanks for the answer but I don't fully understand (I'm a total beginner on electronics).
The error on the 1/10V scale factor is given as 0.25% in the data sheet, so I thought that the difference between the measured value would be 1%=4x0.25% which is quite large.
How should I understand the parameter "nonlinearity" in the data sheet, which you were referring to? Is it correct that it is the maximum difference between the expected and measured output?
Also, do you mean that I should adjust the input DC offset? Indeed there was a small input DC offset, but I am not sure how that would affect the scale factor.
Online David Hess
  • DavidH
« Reply #9 on: December 07, 2020, 10:23:00 pm »
The maximum X non-linearity is specified as 1% and the Y non-linearity 0.4% and since you are using both, they both contribute error.  The similar X and Y feedthrough each also contribute to output error because of how you are using the device.
The scale voltage error and output offset voltage can be calibrated out.
