Electronics => Beginners => Topic started by: klaus11 on February 25, 2016, 02:33:00 pm
Title: Linear LTC2057XX
Post by: klaus11 on February 25, 2016, 02:33:00 pm
After reviewing the datasheet several times, I do not find the Peak output voltage (Vom). Can you help?
http://cds.linear.com/docs/en/datasheet/2057f.pdf (http://cds.linear.com/docs/en/datasheet/2057f.pdf)
Title: Re: Linear LTC2057XX
Post by: RobK_NL on February 25, 2016, 02:57:45 pm
I have no idea what you mean by "Peak output voltage", but as you can see on page 4 of the datasheet, the output goes to within 10mV of the supply voltage for a 'no load' condition.
