The first PSU doesn't have to be a Rigol DP832 right away.
At work we bought some of these:
https://uk.farnell.com/tenma/72-2690/bench-power-supply-1-ch-30v-5a/dp/2563982While it looks like your usual old school twiddly knob analog PSU its actually a fully digital one. Both knobs are encoders that let you set the voltage and current on any digit resolution, it reacts instantly to the setting, the 7 segment readouts update fast and offer 1mA resolution, has manually resetable OCP protection. The thing starts up instantly and keeps last setting just like a analog one. If you want you can also get a model with a RS232 or USB interface for SCPI remote controll. Only downside is the fan control is a bit noisy at low speeds(fan PWM noises and keeps dancing around in speed).
Also not saying a lab PSU is the way to charge batteries. I still use standard purpose built chargers for things like Ni-MH AAs or 18650s, but when i have some non standard pack like a 3 series Ni-Mh or lead acid or a pouch type lithium with wires coming out of it etc.. i just hook it up to a lab PSU because having banana terminals and cables for banana to various clips makes it easy to hook up the battery, and i like to see the voltage and current for these batteries where i am unsure if they are dead or still work.
For the price of 77€ i think it is definitely worth having versus using wallwarts or hacked together PSUs.
The next not so expensive but really useful thing is a hot air station. They can be had for under 50 bucks but makes working with small SMD components so much easier.
