Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Determining ability of MSP430FR6989 GPIO to source/sink current
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Determining ability of MSP430FR6989 GPIO to source/sink current (Read 1383 times)
Mattjd
Regular Contributor
Country:
on:
October 16, 2017, 05:53:43 pm »
Hey, I am using the MSP430FR6989 to control the duty cycle of an RGB led. I have the RGB cathodes connected to GPIO with the CCRx registers of Timer B multiplexed to those pins. I am connecting the common anode to the 3.3 supply of the GPIO. I am trying to figure out how to determine the typical current sink/source of the GPIO to determine the resistors that should be used between the cathodes and GPIO. The forward voltages of the RGB are respectively 1.8,2.8, and 2.8. I've been looking through this data sheet for a while now and am not finding what I am looking for.
http://www.ti.com/lit/ug/slau627a/slau627a.pdf
Logged
ebclr
Super Contributor
Country:
Re: Determining ability of MSP430FR6989 GPIO to source/sink current
Reply #1 on:
October 16, 2017, 06:05:47 pm »
This information is available on the datasheet, if you don't need a very bright rgb, This is a very low power cpu, target to be used with LCD, Datasheet says 2 ma MAX, If you want more use a transistor
http://www.ti.com/lit/ds/symlink/msp430fr6989.pdf
Last Edit: October 16, 2017, 06:08:55 pm by ebclr
Logged
Mattjd
Mattjd
Regular Contributor
Country:
Reply #2 on:
October 16, 2017, 06:23:07 pm »
What table did you view to find this on the datasheet?
Logged
viperidae
Frequent Contributor
Country:
Reply #3 on:
October 18, 2017, 09:36:33 am »
Look at page 48 and 49. By the looks of the graphs, output impedance is 15 to 20 ohms.
3v in, 20mA out gives you about 1.75v on the output pin
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
