Author Topic: Old bridge rectifier?  (Read 1774 times)
Offline just5554
  • Country: lt
« on: June 21, 2016, 02:06:10 pm »
Found in village, can someone tell me something? is it dangerous or something? maybe it's expensive? i dont understand russian :D now i'm keeping it wraped in paper couse it fall apart :D http://www.155la3.ru/avs80_260.htm
Online rstofer
Re: Old bridge rectifier?
« Reply #1 on: June 21, 2016, 02:36:28 pm »
It looks like a selenium plate rectifier.  https://en.wikipedia.org/wiki/Selenium_rectifier
Selenium isn't good for you so wash your hands after handling.
Or, maybe it is good for you but around here there is a lot of excitement about selenium being washed out of farm land and winding up in the rivers.
The following users thanked this post: just5554
Offline N2IXK
« Reply #2 on: June 21, 2016, 03:46:42 pm »
I agree, selenium bridge rectifier.  They were common before silicon diodes became available, but quickly became obsolete afterward. They had a high forward voltage drop, poor efficiency, and often gave off a terrible, toxic stench when they failed.
Selenium is an essential trace nutrient, but quickly becomes toxic at higher levels.
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline Ysjoelfir
« Reply #3 on: June 22, 2016, 03:46:00 pm »
That is definitely a selenium rectifier! And yes, they can smell really badly when dying.. Here in Germany some of us call them Selen "Gleich-riecht-er" which translates to selenium "soon-he's-going-to-smell".
But I actually like them. Quite nice fiddling around with - have a go!
Greetings, Kai \ Ysjoelfir
Offline karoru
« Reply #4 on: June 22, 2016, 04:47:46 pm »
To be honest most of funky smell emergencies were coming from small rectifiers found in radios, TVs and so on. Big ones weren't that bad, I've seen many car battery chargers made using selenium rectifiers still alive and kicking after >50 years of use - most problems with them comes from rust on connectors or being a bit on the zappy side because of exposing them to rain. All these 'smart, intelligent and good in bed' chargers nowaday will probably desolder themselves, borrow money from your wallet and take a cab to electro-dump facilities long before that.
Offline N2IXK
« Reply #5 on: June 22, 2016, 05:33:26 pm »
IIRC, older battery chargers used copper oxide rectifiers rather than selenium, because of the lower forward voltage drop. They looked quite similar to the selenium units, though.
Offline just5554
  • Country: lt
« Reply #6 on: June 22, 2016, 05:51:27 pm »
but nowadays compare sizes of 4x1n4007 and selenium b.r. we can see big difference, and ofcourse i think it's way easier to make bridge rectifiers now. :)
Offline jitter
« Reply #7 on: June 22, 2016, 06:43:08 pm »
Hmm, it says the lifetime is "at least 2000 hours". That's not very much, is it?
That reminds me: we saw one in a different shape in the last Mailbag episode (#888): https://youtu.be/VKJ1h6ThW3Y?t=1062.
« Last Edit: June 23, 2016, 04:37:06 am by jitter »
Offline karoru
« Reply #8 on: June 22, 2016, 07:35:02 pm »
Interesting, they tended to be advertised as 'selenium', but probably anything that looks
like central heating radiator would be marketed at automobile market as selenium no matter if it's oxide type or an actual selenium. I don't have any at home at the moment, I should investigate when I visit my family:)
Just5554 - 1N4007 is 1A diode, it would melt when used to charge your usual 50 Ah car battery;)
After era of plate rectifiers people started to use these "spark-plug lookalike" diodes, which still
can serve well for throwing it at people with intention of inducing blunt trauma.
