Author Topic: Is Sodium Persulphate going to attack heatshrink?  (Read 2172 times)
Offline NoizeTopic starter
« on: October 08, 2012, 03:15:31 pm »
I am currently building an etching tank set up with 25 watt aquarium heater, and air pump.  A thermistor comparator circuit will control the heater.
I will be using sodium persulphate at 45c for the etchant.
I am going to waterproof the thermistor with heatshrink, is that suitable(is the sodium persulphate going to attack it.) or is there better stuff than heatshrink?
Haven't got any heatshrink to test unfortunately, going to get some.
Just thought about putting the thermistor in a test tube full of johnsons baby oil(mineral oil) and immersing that, but it probably has too slow response?
By the way sodium persulphate starts to decompose at 50c
« Last Edit: October 08, 2012, 03:20:59 pm by Noize »
Re: Is Sodium Persulphate going to attack heatshrink?
« Reply #1 on: October 08, 2012, 03:51:43 pm »
Use a heatshrink with an internal adhesive layer, which will melt to form a waterproof seal around your sensor.
« Reply #2 on: October 08, 2012, 04:15:21 pm »
Nice I will get some of that thanks  :)
Offline Alana
« Reply #3 on: October 09, 2012, 07:33:08 am »
In case of lack of the shelf solution the usual replacement is pot sensor in hot glue, then shrinkwrap it. Tested, had no problems up to now.
