Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Pairs of anodes and cathodes on one LED?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Pairs of anodes and cathodes on one LED? (Read 775 times)
cbowen
Contributor
Country:
on:
May 27, 2019, 03:33:39 am »
Hey all, just curious why there would be redundant connections on one LED, as seen here:
https://cdn.samsung.com/led/file/resource/2018/09/P_0.5W_Super_Red_SPMSR1346EA0_Rev.00.pdf
I thought maybe it was for ease of placing LED's in series, but with the same connections on the same side, that can't be it. Is it just for redundancy in case a solder joint breaks? Am I missing it completely? I do understand why there would be multiple connections on a multi-color LED, but this is just one color. Thanks!
Last Edit: May 27, 2019, 03:35:20 am by cbowen
Logged
Ysjoelfir
Frequent Contributor
Country:
Re: Pairs of anodes and cathodes on one LED?
Reply #1 on:
May 27, 2019, 06:10:06 am »
I would assume that it is for mechanical stability. This specific package is also used for multi colored LEDs, where more pins are needed.
Logged
Greetings, Kai \ Ysjoelfir
Dabbot
Regular Contributor
Country:
Reply #2 on:
May 27, 2019, 06:17:37 am »
It also serves to remove more heat from the device.
Logged
cbowen
Contributor
Country:
Reply #3 on:
May 27, 2019, 05:23:29 pm »
Thanks everyone. Would I just split the trace from the resistor to both anodes then?
Logged
Ysjoelfir
Country:
Reply #4 on:
May 27, 2019, 06:22:40 pm »
Just place a Poly region
But a split track will also do just fine for a 500mW LED.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
