Author Topic: amps in cell towers  (Read 1061 times)
Offline LaserTazerPhaserTopic starter
amps in cell towers
« on: May 11, 2019, 07:06:39 am »
What RF transistors do they employ in those pole or other shaped cell tower radio transmitters? Maybe someone here can post whats inside, they likely have very useful power parts.
Offline OwO
  • Country: cn
  • RF Engineer.
Re: amps in cell towers
« Reply #1 on: May 11, 2019, 09:01:19 am »
Email: OwOwOwOwO123@outlook.com
The following users thanked this post: LaserTazerPhaser
Online oPossum
« Reply #2 on: May 11, 2019, 09:04:53 am »
Several teardown videos of cellular equipment by forum member madsbarnkob
https://www.youtube.com/channel/UCSukTlgTEWiL-sl0UeYeJvQ/videos
Offline Nitrousoxide
« Reply #3 on: May 20, 2019, 03:04:18 pm »
LDMOS n-type transistors are fairly common in power amplifier design. Typically these are done on a silicon process, but you can get ones made on GaAs and GaN (or your preferred flavor).
You may sometimes even find that there are two N-type devices in the single package. This is convenient as it allows for Doherty, balanced or push-pull configurations.
I know Gallium Nitride (GaN) is seeing increasing use in DC-DC converters due to their lower loss and higher breakdown voltages (they are also direct bandgap compared to indirect for silicon). However, they are a pain to control as they are depletion mode devices.
