Author Topic: Cheap DC-DC LM2596 Module for negative rail  (Read 1914 times)
Offline jadewTopic starter
« on: February 14, 2014, 02:55:57 am »
Hello,
So I got these LM2596 modules from ebay and by the look of the datasheet it appears that they can be used as inverting buck-boost.
The only difference I noticed in the datasheet (between normal and inverted) is the fact that the ground and the output become reversed.
I tried it, but it doesn't work, it just draws all the current it can draw from the supply.
Any thoughts?
Datasheet: http://www.onsemi.com/pub_link/Collateral/LM2596-D.PDF
« Last Edit: February 17, 2014, 01:31:00 am by jadew »
