Electronics => Beginners => Topic started by: jadew on February 14, 2014, 02:55:57 am
So I got these LM2596 modules from ebay and by the look of the datasheet it appears that they can be used as inverting buck-boost.
The only difference I noticed in the datasheet (between normal and inverted) is the fact that the ground and the output become reversed.
I tried it, but it doesn't work, it just draws all the current it can draw from the supply.
Any thoughts?
Datasheet: http://www.onsemi.com/pub_link/Collateral/LM2596-D.PDF (http://www.onsemi.com/pub_link/Collateral/LM2596-D.PDF)
