I have been dismantling old UPS units for a while. A lot of them were older and used 60HZ transformers. I just too apart one the other day that was rated 550VA output. I intend to use as a step down transformer putting in 120V to the old 120V output. The old primary was 3 wires between the ends is about 16V and it has one center tap lead. These wires appear to be 10AWG.
Wondering if there is a way to find the max amperage for the larger secondary winding. I don't know if it would still be 550VA, if so how do I convert that to Amps? I also saw one unit that was like a 2500VA and had 2 transformers in series on the drive side each appeared to be 24V. How would I find the rating on those?
I did try to Google on occasion, but they seem to be off brands that all I get info on is people fixing or taking apart UPSs with questions on windings, etc.
