Author Topic: How do we simulate a real voltage (non-ideal) source with LTSpice?  (Read 6036 times)
Offline AQUAMANTopic starter
For example if we buy a +5 to 12V DCDC converter with a regulated output, sure it is +12V source most of the time
But when you ask to draw significant amounts of current from the source, even regulated voltage sources drop their value momentarily (perhaps for only several us), but this drop can be quite large
After all, this is why we add storage caps on our voltage sources right? To help the DCDC maintain the voltage under strong transient load
But how do I simulate this drop under load in LTSpice? I have a simulation where in order to simulate correctly what happens in real life, I need to be able to view the drop of voltage on the source under load and how it recovers depending on how large the caps are to help it
Offline tggzzz
Re: How do we simulate a real voltage (non-ideal) source with LTSpice?
« Reply #1 on: November 18, 2014, 04:15:10 pm »
You will never have an accurate simulation of real life. But you can have a "good enough" simulation provided that you can define what constitutes "good enough" or "what I don't care about".
Question: why are you doing the simulation? If to see how your circuit will respond to voltage transients, then simply model transients using ideal voltage sources. If to see how the power supply will vary when your circuit is operating, then you will need a model of the specific PSU (good luck getting that) plus all the other non-ideal components such as wires (which are really inductors).
Depending on what your circuit is, you might be able to simply insert a resistor in series with the ideal voltage. But you might also need to insert inductor(s) in the PSU lines. Or more complex inter-dependencies yet.
Offline DanielS
« Reply #2 on: November 18, 2014, 04:23:27 pm »
The easiest way to simulate a "non-ideal" source is simply to add the resistance and inductance in: the resistance provides droop proportional to current and the inductance provides some degree of sagging/surging from transients.
Depending on exactly what you really want to achieve here, this may be good enough to simulate the regulation lag of a DC-DC converter for your purposes.
If it is not, you can add a whole DC-DC converter to your simulations and put up with the increased simulation time.
Offline tggzzz
« Reply #3 on: November 18, 2014, 11:53:17 pm »
Another obvious point. IRL a significant part of your design+implementation will be to ensure that your circuit's performance is unaffected by whatever components happen to be between it and the power station.
« Last Edit: November 19, 2014, 01:04:10 am by tggzzz »
Offline liquibyte
« Reply #4 on: November 19, 2014, 12:31:07 am »
I don't know if this is the kind of thing you're after but you can simulate noise with a behavioral voltage source with V=(white(2e6*time)/10) but beware, it takes forever to solve.
Quick edit:  I've been modelling a transient voltage spike at startup with a pulse voltage as well PULSE(0 18.3 0 5ms 5ms 100u 0 3).
« Last Edit: November 19, 2014, 12:33:10 am by liquibyte »
