Hello,
In my project I need to create 2 ir beams that are fed into a uc digital input and analyzed. So far I found a gate automation module and recreated the schematic in the idea to duplicate for the other channel as well, but somehow there is timing difference between the 2.
My knowledge in op amps is not very good, from the schematic I deduced it has a band-pass filter and amplifier level, a comparator level and an logic inverter level, but not sure if they are applied properly in my design.
The input of the circuit is from a fototransistor or photodiode I presume the first, the type is unknown.
I already made a few revisions, but it`s like the 2 identical circuits do not behave the same way, like the treshold values varies and the uc receives incorect order of feeds and messes the logic.
is my approach incorrect by using 2 identical circuits or should be used 1 with identical reference?
also I noticed that the dividers are very sensitive to voltage changes so I should also have a ldo regulator also included.
regards,
Cosmin
